Output Error and Output Drop
Can someone explain the different between "output error" and "output drop" from show interface command
I'm a lot of output errors in my ethernet interface and output error and output drop are caused by some buffer queue issue and I confused...
Raymond
Bronze
Re: Output Error and Output Drop
The output drops appear whenever system is attempting to hand off a packet to the transmit buffer but no buffers are available. This can happen due to improper queuing done. You can increse output hold queue ( hold-queu out ) interface config command to increae the queue size.
Check this link
http://www.cisco.com/en/US/partner/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#drops
Output Errors - Sum of all errors that prevented the final transmission.
What possible causes for "output errors"?
hardware issue?
raymond
202
