Output errors on GE interfaces increase rapidly on Catalyst 4908G-L3
rfuchser
we have a Catalyst 4908G-L3 where the ouput error counter increase rapidly on all interfaces. We counted on one interface 52 output errors in 6ms. Other errors are not seen on the interface. We are runnning IOS 12.0(7)W5(15d). please find a sh int bellow.
GigabitEthernet2 is up, line protocol is up
Hardware is xpif_port, address is 0001.4391.3808 (bia 0001.4391.3808)
Description: Athenee Access1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, rely 237/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Full-duplex, 1000Mb/s, 1000Base-SX, Auto-negotiation
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 167000 bits/sec, 72 packets/sec
5 minute output rate 648000 bits/sec, 60 packets/sec
1377154195 packets input, 3281737929 bytes, 0 no buffer
Received 141751 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 1499946097 multicast
1199339000 packets output, 3210447947 bytes, 0 underruns(0/0/0)
461569509 output errors, 0 collisions, 0 interface resets
0 lost carrier, 0 no carrier
Prashanth Krishnappa
Are you seeing any performance impact or is it just cosmetic? If it is cosmetic take a look at the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdw40305
If it's affecting performance, what connects to this interface? Also you are running a very old IOS for this box, consider upgrading to 12.0(18)W5(22b
