OUTPUT PROBLEM IN 6509-SUP1
alsayed
Hi!
Another problem on my 6509sup1-2GE.LOOK WHAT HAPPEN TO THE 6509.
HAVE A LOOK:
Router#remote login switch
Cannot remote to switch
Router#show boot
BOOT variable = slot0:c6sup11-dsv-mz.121-20.E2,1
CONFIG_FILE variable does not exist
00:02:17: %ONLINE-SP-6-INITFAIL: Module 1: Failed to synchronize Port asic
00:03:00: %ONLINE-SP-6-TIMER: Module 7, Proc. 0. Failed to bring online because
of timer event
00:03:00: %C6KPWR-SP-4-DISABLED: power to module in slot 7 set off (Reset)
00:03:02: %ONLINE-SP-6-TIMER: Module 2, Proc. 0. Failed to bring online because
of timer event
00:03:02: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Reset)
00:03:02: %ONLINE-SP-6-TIMER: Module 3, Proc. 0. Failed to bring online because
of timer event
00:03:02: %C6KPWR-SP-4-DISABLED: power to module in slot 3 set off (Reset)
00:03:03: %ONLINE-SP-6-TIMER: Module 4, Proc. 0. Failed to bring online because
of timer event
00:03:03: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Reset)
00:03:03: %ONLINE-SP-6-TIMER: Module 5, Proc. 0. Failed to bring online because
of timer event
00:03:03: %C6KPWR-SP-4-DISABLED: power to module in slot 5 set off (Reset)
00:03:04: %ONLINE-SP-6-TIMER: Module 6, Proc. 0. Failed to bring online because
of timer event
00:03:04: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Reset)
t4 : 60315970, t5 : 0000001C, t6 : 6F6E202C, t7 : 00000006addressddressby is no
shutdownutdownigu
!t
interface Fast
s0 : 00000000, s1 : 00000000, s2 : 621E20E8, s3 : 621E20E8ress t
shutdownon
shutd
!n
interface FastEthernet7/8abit
s4 : 622E8C8C, s5 : 00000040, s6 : 60031408, s7 : 602B7E24nh-sp#?
!h
interface FastEthernet7/9ce GigabitEthernet5
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000nterface FastEthernet7/10terface GigabitEthernet5/7
no ip
gp : 618C1DA0, sp : 622ACF88, s8 : 00008847, ra : 6030F538Ethernet7/11
interface GigabitEtherne
no ip addressinter
EPC : 603113BC, ErrorEPC : BFC016DC, SREG : 3400E103cc
!s
no ip address-List entryint
MDLO : 00000000, MDHI : 00000000, BadVaddr : BFBBB7BEnterface Gigabi
no ip addresses
00
shutdownI
Cause 00000024 (Code 0x9): Breakpoint exceptionr
interface Gi
no ip address3tflash:c6msfc
sh
Writing crashinfo to bootflash:crashinfo_20060622-092152a
!w
interfac
no ip addresset6
shutdo
!i
interface FastEthernet7/37 Star
00:01:02: %C6KPWR-SP-4-PSOK: power supply 1 turned on.yt
Config
!a
interface FastEthernet7/38
of timer event
of timer event
of timer event
00:5
00:03:45: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure
console debugging output.
00:03:45: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x61a3c9b4
PC = 0x60128ca8, Cause = 0x1820, Status Reg = 0x34018002
System Bootstrap, Version 5.3(1)
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
rommon 1 >
WHAT CAUSE THIS PROBLEM,HOW CAN I SOLVED THIS MATTER
b.hsu
Level 5
Level 5
The new module could be missing the maintenance partition. Complete these steps to fix the problem:
1. Issue the power enable module command to verify if adequate power is available in the system to turn the power on for a module that was previously powered down. If there is not enough power available, the module status changes from power-down to power-deny.
2. Issue the show module command to check the status of the module.
Refer to Power Management for Catalyst 6000 Series Switches in cisco.com website
