output rate under a serial interface
We have a 72xx router connected to a 36xx router via a 384K
international leased line. I have observed that under heavy
load the 30 secs output rate under the 72xx serial interface
could reach and even exceed 700000 bits/seconds. The
"received clock" under show controllers ser2/0 is 383760.
How can the output rate be more than the actual clock rate
of the line?
thanks
yiorgos
1 REPLY
Re: output rate under a serial interface
How are you defining the output rate? Is this throughput as defined by the show interface command? It is possible to “burst” if I am not mistaken, ergo short sustained higher levels of speed would be normal.
95
