cwy
Overload NAT Problem
I configured NAT (overload mode) in the router, but there was problem about the connection. The error message and configuration are listed below. Please help.
Debug Error:
2w0d: NAT: address not stolen for 192.168.0.26, proto 1 port 256
2w0d: NAT: failed to allocate address for 192.168.0.26, list/map 1
2w0d: NAT: translation failed (A), dropping packet s=192.168.0.26 d=xxx.xxx.xxx.xxx
Configuration:
ip subnet-zero
interface Ethernet0/0
ip address 192.168.0.254 255.255.255.0
ip nat inside
full-duplex
interface Serial0/0
ip address 10.1.1.100 255.255.255.0
ip nat outside
encapsulation frame-relay IETF
no ip mroute-cache
frame-relay map ip 10.1.1.1 20
frame-relay map ip 10.1.1.2 21
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
ip address 10.2.2.2 255.255.255.252
frame-relay interface-dlci 200
router bgp 101
no synchronization
bgp log-neighbor-changes
neighbor 10.1.1.1 remote-as 100
ip nat pool nat 10.10.10.3 10.10.10.3 netmask 255.255.255.240
ip nat inside source list 1 pool nat overload
ip nat inside source static 192.168.0.1 10.10.10.1
ip nat inside source static 192.168.0.254 10.10.10.2
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip route 192.168.1.0 255.255.255.0 Serial0/0.1
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.0.0 0.0.0.255
Thanks!
Andy
Re: Overload NAT Problem
Andy,
How busy is the translation table? You may be overloading the interface. Check and see how many NAT entries you have allocated. (SH IP NAT TRANS). If you have a lot, consider increasing your POOL to include a few more IP's.
Jason
cwy
Hello Jason,
So if I add few more ip address in the pool, the problem may also happen if the interface is overloading? Any suggestion on the no. of ip address in the pool?
Andy
Andy
ip nat pool nat 10.10.10.3 10.10.10.3 netmask 255.255.255.240 -> is this correct?
Try changing your config to the following.
interface loopback0
ip address 10.10.10.3 255.255.255.255.
ip nat inside source list 1 interface Loopback0 overload
212
