Override Tag Priority?...grrrr...Help!
I want to config a trunk port on my switch to override the priority value in any tagged frames. I have read the manual and it seems that this is possible but I cannot seem to figure out the correct syntax for the command that does it.
This is the section from the manual:
switchport priority {default default-priority-id | extend {cos value | none | trust} | override}
no switchport priority {default default-priority-id | extend | override}
Syntax Description
default-priority-id The priority number for untagged traffic. The priority is a number from
0 to 7. Seven is the highest priority.
extend Set the 802.1p priority of the appliance.
• cos value—Override the 802.1p priority of devices connected to the
appliance. The cos value is a number from 0 to 7. Seven is the highest
priority. The cos keyword only applies to the 3524-PWR and the
3548 XL switches.
• none—The appliance is not instructed what to do with the priority.
• trust—Specify that the appliance should trust (honor) the received
802.1p priority from devices connected to it.
override Override the priority of tagged frames with the default value.
How do I use the "override" argument???
Mike
1 REPLY
Re: Override Tag Priority?...grrrr...Help!
Specify whatever priority you want and then use the override command. Here is an example. This command is supported on WS-C3524-PWR and WS-
C3548-XL switches after the 12.0(5)XU version.
http://www.cisco.com/warp/public/473/139.html#Q11
85
