01-27-2004 03:01 AM - edited 03-02-2019 01:10 PM
Hi everybody.
I have two 7200VXR interconnected via PA-A3-E3 interfaces. E3 link sometimes be unstable with
high CRC errors level (20-50 CRCs) during short
time (1..2sec). In 99.9% of cases, ATM interface
flaps down/up, but sometimes it hangs. I used
clear ip interface ATM1/0 or shutdown/no shutdown commands as solution. Probably it is a bug, but what kind of bug ? in IOS, in hardware ? ...
Routers configuration avalable on:
http://www.univ.kiev.ua/~roman/ospf/
In this situation, the main interface ATM1/0 is in up, but subinterface ATM1/0.2 is in down state.
"show atm pvc" command produce following output:
VCD / Peak Avg/Min Burst
Interface Name VPI VCI Type Encaps SC Kbps Kbps Cells Sts
1/0.1 1 0 32 PVC SNAP VBR 2000 1000 94 UP
1/0.2 best_effort 0 100 PVC SNAP UBR 33920 INAC
1/0.2 ua-ix 0 101 PVC SNAP UBR 33920 UP
1/0.2 trasport 0 102 PVC SNAP UBR 33920 UP
1/0.2 unren 0 103 PVC SNAP VBR 4000 3000 50 UP
1/0.2 world 0 104 PVC SNAP VBR 4000 3000 50 UP
1/0.2 video 0 105 PVC SNAP VBR 15000 10000 50 UP
1/0.2 inet_control 0 106 PVC SNAP VBR 1000 512 50 UP
1/0.2 net_control 0 107 PVC SNAP VBR 1000 512 50 UP
02-02-2004 09:41 AM
I have heard of a similar problem, If you specify more bandwidth than the actual interace can't take then flaping may occur. Try out with this solution disable the keepalive in the interface .
02-03-2004 07:30 AM
Which bandwidth are you talking about? The 'bandwidth' interface paramenetr or PVC bandwidth? My PA-A3-E3 configured in the following way:
interface ATM1/0
no ip address
service-policy output CLP_Set
ip route-cache flow
atm clock INTERNAL
no atm ilmi-keepalive
interface ATM1/0.1 point-to-point
bandwidth 34000
pvc 0/32
vbr-nrt 2000 1000
encapsulation aal5snap
ipv6 address 3FFE:240B:0:1::/64 eui-64
ipv6 rip R1 enable
end
interface ATM1/0.2 point-to-point
bandwidth 34000
ip address 193.125.78.81 255.255.255.252
ip pim sparse-mode
ip ospf message-digest-key 10 md5 7 ********
bundle Main
oam retry 5 5 10
oam-bundle manage 1
pvc-bundle net_control 0/107
vbr-nrt 1000 512 50
precedence 7
no bump traffic
protect vc
pvc-bundle inet_control 0/106
vbr-nrt 1000 512 50
precedence 6
bump traffic
protect group
pvc-bundle video 0/105
vbr-nrt 15000 10000 50
precedence 5
bump explicit 7
bump traffic
protect group
pvc-bundle world 0/104
vbr-nrt 4000 3000 50
precedence 4
bump traffic
protect group
pvc-bundle unren 0/103
precedence 3
bump traffic
protect group
pvc-bundle trasport 0/102
precedence 2
bump traffic
protect group
pvc-bundle ua-ix 0/101
precedence 1
bump traffic
protect group
pvc-bundle best_effort 0/100
precedence other
bump traffic
protect group
