PA-FE and Inter-Vlan routing
Could anyone help me make it clear that if the new revision of PA-FE/PA-FE-FX/PA-2FE supports Inter-Vlan routing with the encapulation dot1q or ISL?
Any tip would be appreciated!!!
Ps: the platform is 7206VXR.
Thanks!
VIP Purple
Re: PA-FE and Inter-Vlan routing
what do you mean with revision of the PAs ? Do you mean the IOS version ? ISL and DOT1Q are supported since IOS 12.0(3)T.
Georg
The first PA-FE-FX which I got about 2 years ago can not support Vlan encapulation even with the latest IOS version at that time, while the IOS features guide said it could. And now in the date sheet of PA-FE/PA-2FE, there is only ISL encapulation support listed.
So I think it could be the problem of hardware revision. May the latest PA-FE could support the inter-vlan routing with Dot1q or ISL.
I wanna make it clear please!
thanks!
Anyone here has tried to use PA-FE to perform inter-vlan routing?
86
