Webcast-Catalyst9k
PA-FE-FX insert hot into Cisco 7206
Can someone advise me if a PA-FE-FX can be "hot" inserted into Cisco 7206 without causing problems or outage ?
Any tip will be much appreciated
1 REPLY
Bronze
Re: PA-FE-FX insert hot into Cisco 7206
Yes, it does support OIR and should cause no problems at all:
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_rout/cfig_nts/2659v2fe/2899nst.htm#1029851
However, I would still recommend that you do it when the traffic passing through the router is low.
HTH.
74
