PA-GE and PA-POS-OC3 on a 7206 Router w NPE200
I would need to activate a 155Mbps link on a 7206 router:
cisco 7206 (NPE200) processor with 122880K/8192K bytes of memory
It is possible to insert a PA-POS-OC3 board on such a router model ?
And there is a GigaEth Port Adapter for 7206 ?
It seems that the PA-GE is not supported on 7206 NPE-200 models.
Thank you.
Alessandro Asson
1 REPLY
Re: PA-GE and PA-POS-OC3 on a 7206 Router w NPE200
Yep, PA-GE is supported only on 7200s with NPE 300 and later.
YOu can install PA-POS-OC3 module on a 7200 with NPE 200
Are you using a 7200 VXR ? For VXRs you need a min of 12.0(3) IOS, for supporting PA-POS-OC3 module. Your ram indicates you have a NPE 200 with 128 MB of RAM. .
Do you have 16MB FLASH ? Most of the 12.x images might need 16Mb flash.
207
