PA-MC-8E1/120 no Work
after all a morning of flapping in a line, the card lets attend traffic. The problem I am solved reinsert the card. It is possible that it is a software error? Is some bug associate to flapping that it causes that the card fails?
I enclose the show ver:
IOS (tm) RSP Software (RSP-JSV-M), Version 12.1(10)E7, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 27-Mar-02 14:41 by eaarmas
Image text-base: 0x60010958, data-base: 0x616BE000
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.1(10)E7, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
rcba2 uptime is 12 weeks, 2 hours, 38 minutes
System returned to ROM by reload at 14:36:43 UTC Thu Aug 21 2003
System restarted at 16:39:14 DST Thu Aug 21 2003
System image file is "slot0:rsp-jsv-mz.121-10.E7.bin"
cisco RSP4 (R5000) processor with 262144K/2072K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
Channelized E1, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Chassis Interface.
4 VIP2 R5K controllers (2 FastEthernet)(32 E1).
2 FastEthernet/IEEE 802.3 interface(s)
80 Serial network interface(s)
123K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 6 is running Cisco Internetwork Operating System Software
IOS (tm) RSP Software (RSP-DW-M), Version 12.1(10)E7, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Compiled Wed 27-Mar-02 14:55 by eaarmas
Slave: Loaded from system
Slave: cisco RSP4 (R5000) processor with 262144K bytes of memory.
Configuration register is 0x102
Fran
  • Other Network Infrastructure Subjects
Silver
Re: PA-MC-8E1/120 no Work
As such i have not heard of any bug that will resolve the problem just by reinserting the card , I guess there was some problem in insertion of the cards , which was solved when you reinserted it
The card was working without problems, seems to be that flapping of the line I cause that the card did not attend traffic
Fran
91
