PABX co trunk connect to 2901 FXS port problem
Dears,
please help to advise how to analyse the error information as below:
show logging
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 168 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 170 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 43 message lines logged
        Logging to 168.70.164.18  (udp port 514, audit disabled,
              link up),
              42 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 168.70.164.19  (udp port 514, audit disabled,
              link up),
              43 message lines logged,
              filtering disabled
        Logging to 168.70.164.20  (udp port 514, audit disabled,
              link up),
              filtering disabled
        Logging Source-Interface:       VRF Name:
Log Buffer (512000 bytes):
*Jan  2 00:00:03.927: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan  2 00:00:04.123: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = uck9 and License = uck9
*Aug  7 10:33:59.639: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-Service-Engine0/0
*Aug  7 10:34:06.479: %PVDM-6-UNSUPPORTED: Codec G.723 is not supported on PVDM3.
*Aug  7 10:34:12.239: %CTS-6-ENV_DATA_START_STATE: Environment Data Download in start state
*Aug  7 10:34:14.755: %PA-3-PA_INIT_FAILED: Performance Agent failed to initialize (Missing Data and APPX License)
*Aug  7 10:34:15.007: VOIPHA: removing default handlers
*Aug  7 10:34:19.683:  Create voice ha process now......
*Aug  7 10:34:19.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Aug  7 10:34:19.743: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Aug  7 10:34:19.743: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Aug  7 10:34:20.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Aug  7 10:34:20.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Aug  7 18:34:22.031: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:34:22 UTC Thu Aug 7 2014 to 18:34:22 HKT Thu Aug 7 2014, configured from console by console.
*Aug  7 18:34:23.383: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.18 port 0 CLI Request Triggered
*Aug  7 18:34:23.383: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.19 port 0 CLI Request Triggered
*Aug  7 18:34:23.387: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.20 port 0 CLI Request Triggered
*Aug  7 18:34:24.187: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug  7 18:34:24.319: %SYS-5-CONFIG_I: Configured from memory by console
*Aug  7 18:34:25.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Aug  7 18:34:28.795: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(1)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 22-Nov-13 21:04 by prod_rel_team
*Aug  7 18:34:28.839: %SNMP-5-COLDSTART: SNMP agent on host WING_HING_SZN_2_XN583615 is undergoing a cold start
*Aug  7 18:34:29.531: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.18 port 514 started - CLI initiated
*Aug  7 18:34:29.531: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.19 port 514 started - CLI initiated
*Aug  7 18:34:29.531: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 168.70.164.20 port 514 started - CLI initiated
*Aug  7 18:34:41.739: %BGP-3-NOTIFICATION: received from neighbor 172.18.0.97 active 6/0 (CEASE: unknown subcode) 0 bytes
*Aug  7 18:34:41.739: %BGP-5-NBR_RESET: Neighbor 172.18.0.97 active reset (BGP Notification received)
*Aug  7 18:34:41.739: %BGP-5-ADJCHANGE: neighbor 172.18.0.97 active Down BGP Notification received
*Aug  7 18:34:41.739: %BGP_SESSION-5-ADJCHANGE: neighbor 172.18.0.97 IPv4 Unicast topology base removed from session  BGP Notification received
*Aug  7 18:34:47.935: %BGP-5-ADJCHANGE: neighbor 172.18.0.97 Up
*Aug  7 18:34:51.103: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Aug  7 18:34:51.139: DSP0 flex_vic_config_ack Failed. ret code = 0x0031
*Aug  7 18:34:51.139:  pak len 24 0  18  0  0  0  8C  0  0  0  31  0  31  0  0  0  0  0  0  0  0  0  0  0  0
*Aug  7 18:34:51.139: %DSPRM-5-DSP_VIC_CONFIG_NAK: Received VIC config NAK from DSP(0/0), resetting the DSP.
*Aug  7 18:34:51.571: %DSPRM-3-DSPALARMINFO: DSP (0/1) Host keepalive timeout
*Aug  7 18:34:51.571: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/0, changed state to Administrative Shutdown
*Aug  7 18:34:51.871: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/1, changed state to Administrative Shutdown
*Aug  7 18:34:52.171: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/2, changed state to Administrative Shutdown
*Aug  7 18:34:52.471: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/3, changed state to Administrative Shutdown
*Aug  7 18:35:16.667: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
*Aug  7 18:35:16.707: DSP0 flex_vic_config_ack Failed. ret code = 0x0031
*Aug  7 18:35:16.707:  pak len 24 0  18  0  0  0  8C  0  0  0  31  0  31  0  0  0  0  0  0  0  0  0  0  0  0
*Aug  7 18:35:16.711: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/0, changed state to up
*Aug  7 18:35:16.731: Miscellaneous signaling debug data: (ch=2):
0001 0080 ABBA **
*Aug  7 18:35:16.907: Miscellaneous signaling debug data: (ch=0):
0000 0080 ABBA **
*Aug  7 18:35:17.111: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/1, changed state to up
*Aug  7 18:35:17.111: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/2, changed state to up
*Aug  7 18:35:17.111: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
*Aug  7 18:35:17.111: %LINK-3-UPDOWN: Interface Foreign Exchange Station 0/0/3, changed state to up
*Aug  7 18:35:17.115: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
WING_HING_SZN_2_XN583615#show voice call su
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0         -          -  -                     FXSLS_WAIT_SETUP_ACK
0/0/1         -          -  -                     FXSLS_WAIT_SETUP_ACK
0/0/2         -          -  -                     FXSLS_ONHOOK
0/0/3         -          -  -                     FXSLS_ONHOOK
WING_HING_SZN_2_XN583615#show voice call st
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
No active calls found
WING_HING_SZN_2_XN583615#show voice port su
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxs-ls      up    up   off-hook idle     y
0/0/1           --  fxs-ls      up    up   off-hook idle     y
0/0/2           --  fxs-ls      up    dorm on-hook  idle     y
0/0/3           --  fxs-ls      up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Everyone's tags (1)
247
