Community Member
Packet over Sonet via PA-POS-OC3 with direct fiber runs between 7513s
I am currently looking into leasing fiber running directly between two buildings and currently have a 7513 on each end. I would like to know if the PA-POS-OC3SMI port adapter and VIP 2-40 would be all that is required for this? Has anyone had any experience with this?
1 REPLY
Community Member
Re: Packet over Sonet via PA-POS-OC3 with direct fiber runs betw
Do you already have the PA-POS-OC3SMI & VIP 2-40 or do you still have to purchase it ? If you still have to purchase it you might wanna consider going the GigEthernet route as it would be cheaper.
The configuration builder should tell you if you have all the bits & pieces and whether they will work together.
87
