Packet Tracer 6.0 problem
How to open saved *.pka file on another PC? When I try I got message: "The file ... is not compatible for this version of Packet Tracer". I use version 6.0 on both PCs. Thank you.
Everyone's tags (1)
Culd you please provide me
Culd you please provide me the file which you have saved and trying to open on another machine?
2)
Please find attach my packet tracer file try to open it on your system.
hth
*********plz dont forget to rate all usefull posts*********
Your file has been
Your file has been successfully opened on my machine. My file is in attachment. Thank you.
your file is correct.
your file is corrupt. please try to save it once again and try to use it.
That what I say. Any file I
That what I say. Any file I create in Packet Tracer 6.0.1 is corrupt when I try to open it on another machine. And Its not a "feature" of my specified PC. I checked it on several PCs.
OkayUninstall the Packet
Okay
Uninstall the Packet Tracer and reinstall the same and it should work fine.
It was a bug of version 6.0.1
It was a bug of version 6.0.1. Cisco says:
All NetAcad students using the student version of Cisco Packet Tracer (PT) 6.1 should upgrade to PT 6.1.1 as soon as possible. Version 6.1.1 contains an important fix to a bug and helps ensure the correct scoring of Packet Tracer Skills Assessments (PTSAs) in the CCNA Routing and Switching curriculum.
So I just upgraded my PT to version 6.1.1.
2072
