Password recovery on 6500 MFSC2 running 12.1(13)E3
Configuring MfSC2 on new switch, saved config and reset module, enable password not being taken. Break sequence not working, tried all in list with no luck, anyone have a break sequence that works on W2K platform?
Re: Password recovery on 6500 MFSC2 running 12.1(13)E3
I have followed both of these procedures even the simulation of the break sequence and the router just goes right back to the router prompt not rommon. If there is a way to just blow it all out that would work for now, I can restore the config.
The break sequence is differs from os to os. Try the first link
for break sequence. Just recovered password.
http://www.cisco.com/warp/public/701/61.html
133
