patch cord length between two C2950SX-24
hello,
I want to connect two C2950SX-24 that are located in the same cabinet, by their 1000BASE-SX MT-RJ port, does the fiber patch cord must have a minimum length ?
regards
Gold
Re: patch cord length between two C2950SX-24
The minimum patch cable length for all the 1000BASE-X optical GBICs whether multimode fiber or single-mode fiber is 2 meters.
I would assume that it is the same minimum for the built-in 1000BASE-SX ports with MT-RJ connectors.
Hope this helps.
I’m trying to connect a Catalyst 6513 to a Catalyst 2950 using its MT-RJ ports but the switches didn’t link with each other.
I would like to know if you could connect your switches successfully using its MT-RJ ports and which kind of fiber did you use.
Thanks, Thiago
87
