02-24-2010 02:49 AM - edited 03-03-2019 05:52 AM
I want to route all traffic received from a subnet (for example, 192.168.10.0/24) through a particular interface (FastEthernet0/1). For this reason, I've implemented a route map with "set ip next-hop":
interface FastEthernet0/0
ip address 192.168.200.1 255.255.255.0
interface FastEthernet0/1
ip address 192.168.250.1 255.255.255.0
interface FastEthernet1/0
ip address 192.168.100.2 255.255.255.0
ip policy route-map MAPA_RUTA
ip route 0.0.0.0 0.0.0.0 192.168.200.2
ip route 192.168.1.0 255.255.255.0 192.168.100.1
ip route 192.168.10.0 255.255.255.0 192.168.100.1
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
route-map MAPA_RUTA permit 10
match ip address 100
set ip next-hop 192.168.250.2
But I have a problem. If the FastEthernet0/1 goes down, I don't want the traffic from 192.168.10.0/24 to be routed though FastEthernet0/0 (as indicated by the default route). Is there any alternative to "set ip next-hop" to do it? I've tried "set ip default next-hop" but I have a similar problem.
Best regards and thanks in advance,
César.
02-24-2010 03:03 PM
Hi Cesar,
You donot want it routed though fa0/0, so you want it be dropped?
02-26-2010 02:52 AM
Hi Lei,
Yes, I want it be dropped. I don't want this traffic to pass though the router attached to fa0/0. If there is no alternative to the "set ip next-hop" with route maps, I've thought to using an ACL in the fa0/0.
Best Regards.
02-26-2010 06:17 AM
Hi Cesar,
You can change your route-map to
set interface null0
HTH,
Lei Tian
