07-26-2002 12:03 AM - edited 03-02-2019 12:11 AM
I have 3 routers called A,B and C.
A and C are the uplink routers for B. ie <- A<-> B <-> C ->
A is on E5/0 of router B and
C is on E5/1 of router B.
on e5/0 (B): ip address 192.168.1.2 255.255.255.252 (gateway to A is 192.168.1.1)
on e5/1 (B): ip address 192.168.2.2 255.255.255.252 (gateway to C is 192.168.2.1)
Then I have networks 192.168.4.0 which I want to exit to gateway A (e5/0) and I have 192.168.5.9 which I want to exit to gateway C (e5/1).
Then in router B, I have a statement: ip route 0.0.0.0 0.0.0.0 192.168.1.1
My config in PBR as follows:
int eth5/0
ip policy route-map exittoA
int eth5/1
ip policy route-map exittoB
access-list 115 permit ip 192.168.4.0 0.0.0.255 any
access-list 116 permit ip 192.168.5.0 0.0.0.255 any
route-map exittoA permit 10
match ip address 115
set ip next-hop 192.168.1.1
route-map exittoB permit 10
match ip address 116
set ip next-hop 192.168.2.1
Then I did a traceroute from a workstation 192.168.5.2, it will exit to 192.168.1.1 instead of 192.168.2.1 and vice versa too.
Is there something wrong with the config that I have?
Thank you for your help.
07-26-2002 02:26 AM
I don't understand why you need PBR for this.
PBR is for routing decision based on something else than just the destination address.
In your case you only talk about the destination, so PBR should not be necessary.
I would suggest to configure the following static route and remove all PBR config:
ip route 192.168.5.0 255.255.255.0 192.168.2.1
07-26-2002 02:15 PM
gdufour,
Hmm but 192.168.5.0 is not originating from router B instead it originates from C.
So If I did ip route 192.168.5.0 255.255.255.0 192.168.2.1 on router B
then the routes will be bouncing back between B and C.
There is an ATM interfaces on router B that is going to use 192.168.5.0/24
So if in router C I did,
ip route 192.168.5.0 255.255.255.0 192.168.2.2
then if in router B I did,
Doesn't it create a bounce route?
Thanks.
07-30-2002 02:01 AM
Are you trying to trace from the router with the policy applied, or from behind it? You'll have to do local-policy to get the policy to apply to packets generated by the router itself.
Russ
