Community Member
PBR with 3550-12G problem
I have 3 vlans (ID 101~103) enable ip routing
ip route 0.0.0.0 0.0.0.0 gateC
3 defferent gateway at vlan103
gateA,B,C which has static route vlan101,2 gw vlan103
and direct connect to internet
For some reasons I need put
vlan101(some-IP) route to internet from gateA
vlan101(other-IP) route to internet from gateB
vlan102,103 route to internet from gateC
I use access-list and PBR to perform this
It's my configure
access-list 101 permit ip any (vlan102~103)
access-list 102 permit ip some-IP any
access-list 103 permit ip vlan101 any
access-list 112 permit ip vlan102 any
access-list 113 permit ip vlan103 any
route-map test permit 10
match ip address 101
set ip nexthop gateC
route-map test permit 20
match ip address 102
set ip nexthop gateA
route-map test permit 30
match ip address 103
set ip nexthop gateB
route-map test1 permit 10
match ip address 112
route-map test2 permit 10
match ip address 113
interface vlan101 apply route-map test
interface vlan102 apply route-map test1
interface vlan103 apply route-map test2
Problem 1
I found host (pc) in vlan102,3 to internet is very slowly....
but traceroute is ok
Problem 2
pc host in vlan101 traceroute to pc in vlan102 will first go gateC then 3550(vlan102)
(it should skip gateC )
...BPR should low piro then director connect...
routing seems no fair...
any suggest ??
thanks
1 REPLY
Silver
Re: PBR with 3550-12G problem
Please check the following possible problems....
1. VLAN 102 and 103 pointed towards Gateway C. And may be this gateway link to Internet is congested enough, so that feeling slow response.
2. For the second problem, it's purely depends upon your configuration. I am not clear about your configuration, but please check with and without route-maps on VLAN 101 and 102 interfaces and removing route-map on only one interface at once. There should be some routing configuration to point to Gateway C first.
94
