06-10-2003 12:19 PM - edited 03-02-2019 08:02 AM
We purchaged some MEM-C6K-ATA-1-64M PCMCIA ATA flash card fro our 6509 (SUP2, MSFC2) and we are getting these errors:
Console> (enable) dir slot0:
error = -24
Open device slot0 failed (bad device info block)
Console> (enable) format slot0:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters):
Unknown device mfg id (5d.75.ffffffea)error = -1
Format device slot0 failed (unspecified error)
The Catalyst 6509 are new as well as PCMCIA card.
Console> (enable) sh ver
WS-C6509 Software, Version NmpSW: 7.3(1)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Jul 8 2002, 16:10:20
System Bootstrap Version: 7.1(1)
Hardware Version: 3.0 Model: WS-C6509 Serial #: TSC0708002N
PS1 Module: WS-CAC-2500W Serial #: ART0701001F
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL063765U1 Hw : 3.10
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.3(1)
Sw1: 7.3(1)
WS-F6K-PFC2 SAL06376695 Hw : 3.3
2 16 WS-X6516-GBIC SAL06468JX3 Hw : 5.3
Fw : 6.3(1)
Sw : 7.3(1)
3 16 WS-X6516-GBIC SAL0651A8V9 Hw : 5.3
Fw : 6.3(1)
Sw : 7.3(1)
4 16 WS-X6516-GBIC SAL0706CFYZ Hw : 5.3
Fw : 6.3(1)
Sw : 7.3(1)
5 16 WS-X6516-GBIC SAL0707D2L5 Hw : 5.3
Fw : 6.3(1)
Sw : 7.3(1)
6 0 WS-X6500-SFM2 SAL0705CDGB Hw : 1.3
Fw : 6.1(3)
Sw : 7.3(1)
7 48 WS-X6548-RJ-45 SAL0706CUAH Hw : 5.2
Fw : 6.3(1)
Sw : 7.3(1)
15 1 WS-F6K-MSFC2 SAD063702W5 Hw : 2.5
Fw : 12.1(11b)E4
Sw : 12.1(11b)E4
How can we make these PCMCIA working ?
06-10-2003 12:22 PM
You might have to upgrade CAT OS
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm#379543
Also, for flash cards over 24M, you'll need to use disk0: rather than slot0:
Try doing a "dir disk0:" after you upgrade
06-10-2003 12:25 PM
Still does not work:
Console> (enable) dir disk0:
Open device disk1 failed (unknown device)
Console> (enable) format disk0:
Format device disk0 failed (unknown device)
06-10-2003 12:28 PM
You will need CAT OS 7.5(1) or later. I suggest that you upgrade to 7.6(1)
