Peculiar problem (collision) in Internet Router
Hi, we are facing peculiar problem in Router. In our Internet Router (2610) E0 we are getting lot of collisions & deferred. I had undergone the steps to solve the problem.
The Setup is link this:
Router-->Packeter--->Switch-VLAN-->Firewall-->Network
(Bandwidth
Analyser)
1.Changed the Router E'net cable
2.Removed the Packeter & Connected to Switch then FW
3.Removed from Switch, Port Settings & Connected to Firewall directly with out any device intermediate
4.Changed the Router E'net cable
After all the changes nothing is working out. Then we changed the Router but problem is not resolved.
10 Mts E'net interface Report is below
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 00b0.6433.7da0 (bia 00b0.6433.7da0)
Description: INTERNET E'NET
Internet address is
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, rely 255/255, load 4/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:35:35
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 211000 bits/sec, 70 packets/sec
5 minute output rate 161000 bits/sec, 65 packets/sec
119826 packets input, 27867293 bytes, 0 no buffer
Received 46 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
126214 packets output, 43044666 bytes, 0 underruns
0 output errors, 482 collisions, 0 interface resets
0 babbles, 0 late collision, 968 deferred
0 lost carrier, 0 no carrier
Please give me a solution what shall we do next to sort out this problem
Rgds/Sri
1 REPLY
Re: Peculiar problem (collision) in Internet Router
Have you tried manually setting the ethernet interfaces on both sides to full duplex? Cisco autonegotiation often does not work well with other vendor ethernet interfaces.
hth
Bill
87
