Community Member
Per-Packet and Per-Destination load balancing on same router?
Hi All,
Is it possible to do Per-Packet and Per-Destination load balancing on same router? I have two 3620 routers connected by 2 parallel T-1 leased lines. Most traffic consists of:
1. Large TCP file transfers between one or two hosts. Mostly late afternoon and early evening. I would like to do Per-Packet here to utilize full bandwidth.
2. VoIP UDP traffic between many hosts, mostly early morning. I would like to do Per-Destination here to avoid Jitter and out of order UDP packets.
I don't think PPP Multilink can help me here, I have enough bandwidth so I don't need link fragmentation & interleaving. Any ideas?
Thanks, Randy
Re: Per-Packet and Per-Destination load balancing on same router
I dont think this is possible, unless you do it manually by configuring the appropriate commands at the respective times
Community Member
try a time based access-list in order to prefer voice packet in the morning and then data packet in the afternoon
it need some research , if you find it hard pls email me
tks
Community Member
Do you have CEF enabled. I am not sure if it will help you in this situation, but I think it is worth a shot. CEF does load balancing via per-destination and per-packet.
see if this helps
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094806.shtml#whatis
90
