Per packet balancing issue
I' ve two frame relay circuits configured between a Cisco 7500 ad a Cisco 2600.
For the remote LAN, on the 7500 side I've configured two static routes, one to the subinterface P-t-P of the first pvc and the other to the second subinteface (with the same cost)
At the "serial interface" level for the two routers configuration, I've specified the " no ip route-cache " option to overcome the "per destination balancing".
In this situation I'd think that the two link for the same destination, will be equally used?
But.... If I look the traffic statistic on my MRTG, I see that the first link is a little beat more used... why?
thanks in advance!
Graz.
1 REPLY
Re: Per packet balancing issue
I've found the issue: ther is a the " ip cef distributed "enabled at the global level!
I've to disable cef on the related interface..
Bye,
Graz.
81
