per port ACL on 2950
port based ACL is possible on 2950? i mean my requirement as follows on a vlan having diff. network segment, switches are vlan 5, servers vlan 6, clients vlan 7, pc vlan 8,they interconnect each other, layer 3 - 3750, layer 2 - 2950, on one of the switch port fas 0/1 a pc is connected ip address 192.168.1.1/24, only a pc having 192.168.1.1/24 connected on this port can access other pc/server on the network, if the pc ip address is been changed to 192.168.1.2 ,it should not reach other pc/server, i think it is possibile with the following
switch configuration
interface fastethernet 0/1
switchport access vlan 8
switchport mode access
ip access-group 101 in
spanning-tree portfast
interface gigabitethernet 0/1
description ***connected to 3750***
switchport mode trunk
interface vlan 5
ip address 10.1.1.2 255.255.255.0
ip default-gateway 10.1.1.254
access-list 101 permit ip host 192.168.1.1 0.0.0.255 any.
am i right? if not correct.
note: in 3750 vlan is configured, i don't wanted to put any access-list on this,as i wanted a port based access-list on the edge switches only, only then it will satisfy my need.
  • Other Network Infrastructure Subjects
Bronze
Re: per port ACL on 2950
Hi anand,
your access list statement
will permit entire 192.168.1.x network with your wild card mask 0.0.0.255
i think you need to change it to
access-list 101 permit ip 192.168.1.1 0.0.0.0 any
or
access-list 101 permit ip host192.168.1.1 any
other config is fine it should work fine.
Raj
If I'm correct, then Switch 2950 is a L-2 switch and doesnt understand anything beyod L-2. Hence I really doubt implementation of a L-3 Access-List on any Physical Port of the 2950 Switch.
Kind Regards,
Wilson Samuel
PS: Please rate if it helps.
Hi Ananad,
Please let us know the model number of the switch 2950. 2950 switch with EMI (enhanced image) we can set the ACLs.
Following switches are the Enhanced image 2950 swicthes (Catalyst 2950G-48, 2950G-24, 2950G-24-DC, 2950T-24, 2950C-24, 2950G-12.
Please refer the link below:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea7/scg/swacl.htm#wp1043920
HTH, Please rate if it does.
-amit singh
Hi Amit,
Thanks for pasting this link.
I'm now updated with the latest developments in the 2950 Series switches.
Kind Regards.
Wilson Samuel
THankz for the reply,
my 2950 is EMI.
700
