per-port per-vlan
Hi All, I am having trouble configuring per-port per-vlan qos. I ahve followed the doc as per the letter, still getting no hits when I display sho policy map int f0/6, details below. Idea is to match vlan 13 incoming to the switch in port f0/6 and set ip prec 2. Spent so long on it now getting really frustrated!! Have posted on usual forums and have had nil response. Thanks for any input, ps mls qos is in config.
config...
class-map match-any port
match access-group 1
class-map match-all vlan
match vlan 13
match class-map port
policy-map vlan-in
class vlan
set precedence 3
access-list 1 permit any
interface FastEthernet0/6
switchport access vlan 13
switchport mode access
service-policy input vlan-in
xxxx35#sho policy-map int f0/6
FastEthernet0/6
Service-policy input: vlan-in
Class-map: vlan (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: vlan 13
Match: class-map match-any port
Match: access-group 1
0 packets, 0 bytes
5 minute rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
xxxx35#
Re: per-port per-vlan
Why do you still want to match on vlan 13? Fa0/6 is already configured as access port in vlan 13.
Does the following work?
policy-map vlan-in
class port
set precedence 3
Hi, I do not think it has worked, have posted complete config for you to look at. I have a router connected to f0/6, this is sending pings to remote switch SVI interface via this one and over a trunk to a remote switch. I am getting responseses back. Basically all on bc domain.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname xxxx35
enable secret xxxx
no aaa new-model
mls qos
ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 13-15 priority 24576
vlan internal allocation policy ascending
policy-map vlan-in
class port
set precedence 3
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport mode trunk
interface FastEthernet0/24
spanning-tree vlan 13-15 port-priority 64
interface GigabitEthernet0/1
switchport mode dynamic desirable
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 1.1.x.x.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password cisco
no login
line vty 5 15
password cisco
no login
end
xxxx35#
FastEthernet0/6
Class-map: port (match-any)
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
xxxx35#
FastEthernet0/6
Ingress
dscp: incoming no_change classified policed dropped (in bytes)
Others: 47523899 13749199 33774700 0 0
Egress
Others: 47686196 n/a n/a 0 0
Bronze
What kind of switch is this? If it is something like a 3550, then you have to turn off flow control on all the ports and enable qos:
conf t
int range f0/1 - 24
no flowcontrol receive
exit
mls qos
end
Hope this helps.
Hi, 3550 emi, flow off on all ints. What I am trying to achieve is catching all pkts from interface f0/6 and marking them as prec2. Looking at the documentation the way forward on this per-port per-vlan, thanks in advance-
config...
match vlan 13
policy-map vlan-in
class vlan
set precedence 3
FastEthernet0/6
0 packets, 0 bytes
Match: vlan 13
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
xxxx35#
it is true that flow control must be off but that is not the issue. the issue here is you are looking at show policy output which is IOS output when all the packets are switched via hardware. If you want to look if particular DCSP value is getting marked or the switch is really seeing the DSCP value, you have to go under the interface and monitor a particular DSCP value.
Switch(config-if)#mls qos monitor dscp 6
no ip address
mls qos monitor dscp 0 6
service-policy input test
Switch#show mls qos interface fa 0/1 stati
FastEthernet0/1
Ingress
0 : 0 0 0 0 0
6 : 0 0 0 0 0
Others: 0 0 0 0 0
Egress
0 : 0 n/a n/a 0 0
6 : 0 n/a n/a 0 0
Others: 0 n/a n/a 0 0
without the mls monitor, there is no way to take the statistics:
Switch(config-if)#no mls qos monitor dscp 0 6
Switch(config-if)#end
9w1d: %SYS-5-CONFIG_I: Configured from console by console
FastEthernet0/1
Ingress
Others: 0 0 0 0 0
Egress
Please rate helpful posts.
Hi bos,
added config as descibed, was getting a lot of hits on other interfaces as well and could not decipher values anyway as I wanted to match all traffic from vlan x and port y and then set an ip prec value. In the end I connected a server to 3550 and extended ping to analyser and was suprised to see traffic being altered by per-port per vlan map, which was good. Thanks all for replies.
130
