Community Member
Periodic Maintenance (Reboot) of Catalyst 4000/6500 Switches
Does anyone know if there is any recommended guidelines for rebooting Cat 4000/6500 series switches periodically to clear buffers, etc (for maintenance?
I appreciate any advice you can give. Thanks.
1 REPLY
Purple
Re: Periodic Maintenance (Reboot) of Catalyst 4000/6500 Switches
There is no maintenance required unless you are having a problem . That's not to say all haven't seen where rebooting a switch fixes broken things. :-)
155
