Webcast-Catalyst9k
Pin out details for DB-15 to RJ-45 for E1 PRI cable
Could some send me the pin out details for CAB-E1-RJ45 cable for CE1 port adapter for 3662 router?
Re: Pin out details for DB-15 to RJ-45 for E1 PRI cable
DB15===RJ45
9======4-Rx tip
2======5-Rx ring
10=====1-Tx tip
8======2-Tx ring
15=====6-Rx shield
7======3-Tx shield
Thanks for the reply. Do you think cable with following pinout connection will work:
DB15 end RJ-45 end
8 -- 4
15 -- 5
7 -- 6
9 -- 1
2 -- 2
10 -- 3
1664
