Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Ping issue
Configuring a 2611 for a test environment. Pretty basic - 2 interfaces. E0/0 connects to network, E1/0 connects to test network. E0/0 10.1.1.10 255.0.0.0
E1/0 192.168.100.1 255.255.255.0
Have IP routing turned on with a default route pointing to our pix 10.1.1.1.
I can ping other switches on the real network from the 2611 and into the 192 network.
I can ping from the network switches to the router and beyond. I can not ping past the 10.1.1.100 interface from the 192 network.
Any thoughts?
Re: Ping issue
I assume the device beyond the router is PIX. Your PIX mayn't have a route to get to the 192.168.100.0/24 network.
Things you need to make sure:
1. Devices on the 192.168.100.0/24 NET has to be configured with a gateway address of 192.168.100.1
2. All devices beyond the router have a route back to the 192.168.100.0 or their default gateway should be pointing to 2611.
HTH,
Sundar
*Please rate all helpful posts.
Green
Re: Ping issue
You may want to verify your subnet masks on all pf the attached devices.
If one of the 10.x.x.x masks are set to something like a 24 bit mask, you'll see the kind of behavior you describe.
This and / or the suggested route issues are the most common mistakes.
Good Luck
Scott
114
