08-07-2003 11:49 AM - edited 03-02-2019 09:26 AM
My network looks like this in the Catalyst 4506:
Internet -- Firewall (10.0.0.253) -- (Vlan 1, 10.0.0.254)some servers (10.0.0.1 and 10.0.0.2) --
(Vlan 2 10.0.1.254) some servers (10.0.1.1 and 10.0.1.2)
(Vlan 3 10.0.2.254) some servers (10.0.2.1 and 10.0.2.2)
Old network (Vlan 4 192.168.168.210)
Catalyst ip route 0.0.0.0 0.0.0.0 10.0.0.253
When I try to ping from the firewall to 10.0.0.1 it works. When I try to ping from 10.0.0.1 to the firewall it won't work. When I try to ping from 10.0.1.1 to the firewall it works, but when I try to ping to 10.0.0.1 it fails.
I have de default gateway set as follows:
Firewall(10.0.0.253) Default Gateway: 10.0.0.254
Server (10.0.1.1) Default Gateway: 10.0.1.254
Al the other servers and pc's in the other Vlan's have there subnet set to the Vlan ip number.
Is there a problem in the routing table?
08-07-2003 12:23 PM
Maybe you have a firewall issue. Is ping allowed both ways (IN and OUT).
08-07-2003 05:30 PM
Make sure that the subnet mask on 10.0.0.1 is set properly.
Mark
