Community Member
ping problem
hi
I have one 2950 switch ,that I have its interface ip address. I can ping my pc but th problem is,i can't ping the switch from my pc.
first ,I want to change the ios & upgrade the ios ,but I can't use tftp .could you pls help me?
thanks
Re: ping problem
Please paste the configuration of the switch.
Your 2950 is a layer 2 switch and you can have only one Vlan interface ( SVI-Layer3 which is used to manage the switch only ) up at any given time. Make sure that your PC is in the same vlan interface which you have given the IP. For example..
if your int vlan 1 is up and have any ip on it.. your PC should be in the same vlan to communicate with the switch for upgrade the IOS.
HTH,
regards,
-amit singh
Community Member
Re: ping problem
sho run
Building configuration...
Current configuration : 1559 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 200.x.x.x.x.255.0
no ip route-cache
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
& the ip address of
my pc is 200.200.200.2 255.255.255.0
Re: ping problem
As per the config you PC is in Vlan vlan make sure that it is in the same vlan.Please check for any Personal firewall on your PC. If its is Windows XP it has a bulit in firewall,please disable that. If you have any other firewall on your system like symantec, norton etc. disable it.
Did you check all the physical layer part/connectivity.
Please paste the output of "Show int Vlan 1".
Please paste the output of the "show interface fa x/y " of the interface where your PC is connected.
regards,
-amit singh
Community Member
Re: ping problem
Switch#sho int vlan 1
Vlan1 is up, line protocol is up
Hardware is CPU Interface, address is 0012.578a.9b40 (bia 0012.578a.9b40)
Internet address is 200.200.202.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:02:04, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
157 packets input, 16738 bytes, 0 no buffer
Received 70 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 7 ignored
775 packets output, 41022 bytes, 0 underruns
0 output errors, 4 interface resets
Switch#
Re: ping problem
Hello...
Check the interface Ip ...
Internet address is 200.200.202.1/24 <<<---
Its showing something different to what you earlier pasted. Check the Ip addressing again on your Vlan interface and the Host PC.
I guess you have wrongly entered the IP addresses on either of these device. Check it again and also the firewall part. If you correct your Ip addresses and still you are unable to ping then it is definetly something to do with the software firewall, or any other software which is not letting the traffic pass through.
HTH, Please rate if it does.
regards,
-amit singh
Re: ping problem
In addition to it can u check weather u r SVI for vlan one is enable or not i mean try a shut and no shut under u r SVI.
Mahmood
128
