Ping , Telnet problem
anil.nair
Hi!
I have two sites with the following configuration on the routers
Site A
interface FastEthernet0
ip address 66.1xx.xx.xx 255.255.255.240
ip nat inside
speed auto
full-duplex
interface Serial0
ip address 64.xx.xx.xx 255.255.255.248
ip nat outside
encapsulation frame-relay
fair-queue
frame-relay map ip 64.xx.xx.xx 16
frame-relay lmi-type q933a
ip nat inside source list 1 interface Serial0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 64.xx.xx.34
ip route 0.0.0.0 0.0.0.0 66.xxx.xx.xx
no ip http server
access-list 1 permit any
end
Site B
interface Ethernet0/0
ip address 192.168.1.2 255.255.255.0
shutdown
interface Serial0/0
no ip mroute-cache
no fair-queue
interface Serial0/2
ip address 66.xx.xx.xx 255.255.255.252
ip nat outside
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-24
ip nat inside source list 1 interface Serial0/2 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/2
ip route 66.xx.xx.0 255.255.255.240 66.xx.xx.xx
ip route 66.xxx.xx.0 255.255.255.240 64.xx.xx.xx
no ip http server
!end
Problem:I am not able to Ping or telnet to the inside of Site A from Site B
Can somebody spare a minute and assist me in solving this problem.
Thanks in Aadvance
anair
mfaust
In order to ping or telnet or do anything else for that matter, you need a route to the destination and the destination needs a route back. Looking at your configurations, I can't tell if you have provided these routes. I do see a couple of things that should be looked at. On router A you have two routes to 0.0.0.0 (one to the Ethernet and one to the Serial?). This doesn't look right. Also, on router B, check your static routes. I can't tell if they are correct because they are X'ed out. Try looking at the routing table. Do both routers have the correct routes in them? (show ip route x.x.x.x). If the routes look correct, try a trace route. Where does the trace die. Try these things and let us know what you find.
