pinging int s0. please help
Hi everyone,
I want to provide remote access to W2K users (they have eicon cards C90) through a X.25 network to my Apache webserver running on a W2K server.I have configured my cisco router like this :
!internal network
interface Ethernet0
ip address 192.168.2.3 255.255.255.0
no ip directed-broadcast
no cdp enable
ip subnet-zero
interface Serial0
description test x.25 link
bandwidth 64
ip address 10.0.0.1 255.255.255.0
encapsulation x25
x25 address 211111
x25 htc 50
x25 win 7
x25 wout 7
x25 idle 5
x25 nvc 2
x25 map ip 10.0.0.2 311111 ! remote user nna address
I can´t ping the remote workstation, and I can't even ping the interface serial 0 from the router. The ping works fine with int e0 and the 192.168.2.0 network.
Silver
Re: pinging int s0. please help
If you can ping directly connected from the router but can not ping sourcing your ping from another interface on the router the problem is most likely the gateway on the remote WS is misconfigured , Do any of the clients have dual Nic's ? If they do, perform a route print and look for discrepencies
I was not clear in my explanation. I am logged in the router from console and when I try to ping the int S0 I only receave ...... . With int e0 the ping works fine.
David
Silver
Check whether the physical link (the x25) itself is up, if it is not, you will not be able to ping your local serial interface
well , sh int s0 returns line is up and protocol is up , Serial 0 is up.
thanks
David
If the interfaces are up and still you can't ping to the other, then I suspect some access-list misconfigurations. Check if icmp is permitted. Take care of the implicit 'deny all' at the end of access-list.
Naveen.
mnaveen@cisco.com
103
