Pinging LAN to LAN works one way
I have 2 CISCO 805 routers connected via a 56K DDS. I can ping each S0 and each EO accross the 56K circuit. The Corporate router can ping hosts on the Warehouse routers E0 but the Warehouse router can't ping hosts on the Corporate router's EO. Here is the configs:
****Warehouse router:
warehouse#wr t
Building configuration...
Current configuration : 748 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname warehouse
enable secret xxxx
enable password xxxx
ip subnet-zero
interface Ethernet0
ip address 192.168.99.1 255.255.255.0
no ip mroute-cache
interface Serial0
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
interface Serial0.1 point-to-point
description ISP
ip address 10.0.0.1 255.255.255.0
no ip mroute-cache
frame-relay interface-dlci 16
ip classless
ip route 192.168.16.0 255.255.255.0 10.0.0.2
ip http server
ip pim bidir-enable
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
password xxx
login
end
warehouse#
****Corporate Router
corporate#wr t
Current configuration : 730 bytes
version 12.2
no service pad
hostname corporate
enable secret xxxx
ip subnet-zero
interface Ethernet0
ip address 192.168.16.1 255.255.255.0
no ip mroute-cache
interface Serial0
no ip address
no ip mroute-cache
no fair-queue
description ISP
ip address 10.0.0.2 255.255.255.0
no ip mroute-cache
ip classless
ip route 192.168.99.0 255.255.255.0 10.0.0.1
ip http server
ip pim bidir-enable
line con 0
stopbits 1
line vty 0 4
password xxxx
login
end
corporate#
Thanks!!
1 ACCEPTED SOLUTION
Re: Pinging LAN to LAN works one way
When the warehouse router pings hosts off corporate router E0, 10.0.0.1 is used as the source address. Make sure that these hosts can reach this address either using a specific or default route.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
Can the warehouse router ping the E0 of the corporate router ? If so you have proven that you have a route to the dest network . If this is so check the gateways of the clients on the ethernet segment of the corporate router.
Another thing you can do is from the corporate router ping hosts on the ethernet segment but source your pings from s0.1 if pings fail the clients gateways are set incorrectly .
***Fixed***. It was the gateway on the clients. Once I set the right gateway I could ping and everything worked perfectly.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
139
