Pinout for a DTE CAB-SS-232MT cable.
can you give me the pinout for the DB25 cable "DTE CAB-SS-232MT" use has a Synchronus interface with the WIC-2A/S on a Cisco 1720.
Also i need to connect this DB25 part of that cable to a DB9 connector in a Service channel on a Nuric radion (# 9420 LX) Alcatel. This service channel his 64 kbps sync.
This DB9 his a V.28 interface here his the pinout.
1- Data in +
6- Data in -
9- Clock A out +
5- Clock A out -
2- Clock A in +
7- Clock A in -
8- Data A out +
4- Data A out -
All - are the reference to common logic.
Wath are the correspondant pins of the DB25.
Thank you.
Luc
3- Earth
1 REPLY
Re: Pinout for a DTE CAB-SS-232MT cable.
Here is the url which discuss all the serial cable pinouts..
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2509/acsvrug/cables.htm#19941
Cable CAB-SS-232MT is a RS-232 DTE cable so EIA/TIA-232 DTE is the one for you...Tejal
1918
