Webcast-Catalyst9k
PIX 506 Port speed and duplex
Here's an easy one but I can't find the answer. Anyone know off hand the tech specs of the port speed and duplex of the the ethernet ports on a PIX 506? Thanks!
1 REPLY
Silver
Re: PIX 506 Port speed and duplex
It depends on your version. 6.3 might allow you to use 100megabit FDX on both interfaces. I believe before this change 10 megabit FDX was the limit. I believe cisco now says that the 506e can do 60 megabit of clear text throughput. You always have been able to hard code auto/full or half duplex, but now speed should be an option too.
Note that the above may be all wrong ;-) - the pix os 6.3 release notes only refer to these changes for 501 and *506e* - I have no idea what happens on a old 506 as I haven't upgraded one yet.
398
СоздатьДля создания публикации, пожалуйста в систему
