PIX - Inside to DMZ connectivity
hptisupport
I am configuring a PIX 515e Software Version 6.1(4) and would like to give access to all traffic accessing the DMZ. I thought this would work: ("dmz" is the interface name)
conf t
access-list acl_dmz permit ip any any
access-group acl_dmz in interface dmz
I still cannot ping the interface or any hosts on the subnet. It obviosly does not work like the "inside" interface.
I realize I am attempting to open the interface completely - I want to get our sustem back up and work from there. After re-establishing connectivity, I will be configuring a VPN tunnel to another new PIX at a remote site. From there I will start closing things down.
I was hoping the configuration was as quick and easy as opening up the other interfaces...
Thanks!
hptisupport
Solved this with the following static entry:
static (inside,dmz1) 10.0.2.0 10.0.2.0 netmask 255.255.255.0
where 10.0.2.0 is the subnet of the Inside interface.
