Please help me what modeule installed in the AS5200.
I want to identify what hardware module installed in the AS5200. please guide me based on the “show version” or what information required to identify.
- 1 Eth
- 2 Serial
- Dual T1/PRI
- I’m not sure for 24 teminal lines and 26 serial network interface.
------------------ show version ------------------
IOS (tm) 5200 Software (C5200-I-L), Version 12.0(8), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 29-Nov-99 22:46 by kpma
Image text-base: 0x22031F04, data-base: 0x00005000
ROM: System Bootstrap, Version 11.2(10)P, RELEASE SOFTWARE (fc1)
BOOTFLASH: 5200 Software (C5200-BOOT-L), Version 11.2(11)P2, RELEASE
SOFTWARE (fc1)
aswhtby1 uptime is 3 weeks, 2 days, 17 hours, 56 minutes
System restarted by power-on
System image file is "flash:c5200-i-l.120-8.bin"
cisco AS5200 (68030) processor (revision N) with 8192K/4096K bytes of
memory.
Processor board ID 14045651
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Mother board with terminator card.
1 Ethernet/IEEE 802.3 interface(s)
26 Serial network interface(s)
24 terminal line(s)
2 Channelized T1/PRI port(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
8192K bytes of processor board Boot flash (Read/Write)
Silver
Re: Please help me what modeule installed in the AS5200.
Here is a link that shows all modules for the As5200 platform.
http://www.cisco.com/en/US/partner/products/hw/iad/ps497/products_installation_guide_chapter09186a008007e293.html
The 26 Serial lines is a combination (total) of your 24 terminal lines and 2 T1/PRI ports.
Hope this helps you,
Don
Looking on show version, AS5200 have two serial ports. 2 Channelized T1/PRI ports and 24 digital modems, 1 10M ethernet port.
Now that 26 serial network interfaces is because of 2 regular serial ports + 24 channels from one of the T1 controller which you may have configured for PRI signalling. That totals 26. Now i can gurentee that the other T1 ports is in "shutdown" mode or not configured for pri. Type "sh run" to confirm. So those 24 channels (serial interfaces) belongs to that 2nd T1 card is not added to 26.
Once you configure other T1 port for PRI, after that "show version" will report
24+24+2=50 total serail interfaces.
24 terminal lines represent 24 modems (line 1 24 in "sh run")
128
