Please help me with my config?
Hi folks,
I am trying to get a 1605r up and running but, my hosts can't seem to get on the internet. I am pretty sure the problem is that my router is not configured to NAT properly.
I can ping my DNS servers from my router but, not from my hosts. See anything wrong with this config?
Thanks, Chris
Current configuration : 662 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname
logging rate-limit console 10 except errors
enable secret 5
ip subnet-zero
no ip finger
interface Ethernet0
ip address dhcp
interface Ethernet1
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
password
transport input none
line vty 0 4
password
login
end
Re: Please help me with my config?
You need to define what is the inside and outside interfaces for your nat statement below.
Under Ethernet 0 add the following command
ip nat outside
Under Ethernet 1 add the following command
ip nat inside
Then you should be able to view translated sessions by using
Show ip nat trans
Travers
Your an ace Travers, thank you!
93
