You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Please Help, switching int from dynamic to static IP
I have a Cisco 1605r that worked fine with optimum online, which used dynamic IP (int e0 had the line "ip address dhcp")
Here is my config:
Building configuration...
Current configuration : 1356 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname
enable secret xxx
ip subnet-zero
no ip source-route
no ip bootp server
interface Ethernet0
ip address 64.xxx.xxx.xxx 255.255.255.0
no ip proxy-arp
ip nat outside
no cdp enable
interface Ethernet1
no ip proxy-arp
ip nat inside
no cdp enable
ip nat inside source list 1 interface Ethernet0 overload
no ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
banner login ^C
WARNING!!!
This system is soley for the use of authorized users for official purposes.
You have no expectation of privacy in its use and to ensure that the system
is functioning properly, individuals using this computer system are subject
to having all of their activities monitored and recorded by system
personnel. Use of this system evidences an express consent to such
monitoring and agreement that if such monitoring reveals evidence of
possible abuse or criminal activity, system personnel may provide the
results of such monitoring to appropriate officials.
^C
line con 0
password
login
line vty 0 4
exec-timeout 0 1
no login
no exec
transport input none
end
The only difference between the old config and the new is that optimum gave me dynamic ip and speakeasy gives me static. I entered the static IP and NetMask but I have no idea how to tell my router what my new DGW and DNS addresses are. Can anyone help me? I can only ping my DGW, I can not ping my DNS servers and my LAN can't reach the web.
Thanks, Chris
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Bronze
Re: Please Help, switching int from dynamic to static IP
My understanding is that in classful routing a default route isn't used for a given packet if there's a route in the routing table for the major network that the packet is destined to. In this case, he should only have a route for 64.0.0.0/8, so packets will take the default route as long as they're not destined for this netblock.
That being said, I'd also recommend using "ip classless" so that you're not blackholed from the entire 64/8 address range.
I think you need to point your default route to the default gateway rather than the Ethernet interface; e.g., ip route 0.0.0.0 0.0.0.0 . I don't know how it worked like that before.
If Speakeasy gave you a static IP, they should have also given you their default gateway address to use, and their DNS servers. Talk to them and you should be good to go.
They gave me my ip, my dgw, my netmask and 2 name servers addresses. I entered all of that info into my router but, still can't ping my dns servers. I am assuming that the old command "ip address dhcp" was automatically performing some function that I now need to do manually but, what that is, I don't know.
Your default route wont be used unless you enable ip classless. Give "ip classless" on global config mode. HTH
Are you sure? It worked fine with my cable modem.
when it worked fine with your cable modem, did you have your router also in place or just the pc hooked to a hub/switch where the cable modem is also hooked into ?
With both my cable modem and dsl modem, I had the modems going into e0 and my lan on e1
The only thing that has changed, as far as I know, is that my public ip address on e0 was given to me dynamically with cable so I used the line "ip address dhcp" then. Now I have a static address so I am using the command "ip address 64.x.x.x 255.255.255.0
I also added the commands
ip default-gateway
and
ip name-server
I can not ping anything past my DGW, I must have something wrong with the way I am routing... I don't know why I can't ping my DNS servers
I tried "ip classless"... no luck! :(
Thanks for your help and time, Chris
Bronze
I will try making a static route to my dgw. That sounds logical. Thank you for your help. I will let you know if it worked.
YOU ARE THE MAN!
Your info worked. I can't thank you enough. Great job!
111
