PLEASE HELP with Cisco 801 ISDN router
Hi all,
I've now used a month on trying to configure this router and i can't figure
it out. Does anybody have some experience with this router. What i want i
should be the easiest thing to configure on this router. To see how my
network should look i've made a link to a small PDF file with the drawing.
Ok here it comes. The provider i have is free because it's from my dads
work. The connection works fine on my computer when i use Eicon Diva ISDN
modem to connect myself. The connection calls up to my dads work. I use a
domain name for it otherwise it won't connect. I haven't seen that field in
Cisco Fast Step software. Another thing is that i think they use CLI since
it's a free number they must have some security that only people from the
company can call this number. I have no idea what type of authentication
they use but can i find it in windows sine it's works there ? Now this
connection is a little bit triky but this is the one i want to use I hope
that somebody have some experience how i've should make this configuration.
Probably i have to use the ISO software.
http://users.cybercity.dk/~dko1224/Network.pdf
PLEASE SOMEBODY
Best Regards
Mihai Marinescu
Denmark
1 REPLY
Re: PLEASE HELP with Cisco 801 ISDN router
Generally the dialup will use CHAP so you'll need to put the chap passwords in the dialer (I always put username and password in case someone changes the router name)
You'll also need to enable EasyIP so the router will negotiate an IP and use that for all PC's on the network.
131
