Community Member
Please help with dhcp!
I have a 871w with dhcp configured on the device. It has build in wireless, and although we can see the broadcast ssids, we cannot connect/get a dhcp address. I have been dealing with this for over a week and cannot determine why I cannot get an IP. Please help, an office of 6 workstations are all on wireless, and I fear that if this goes into next week, I will have to get cabling guys in.
Thanks all!
Silver
Re: Please help with dhcp!
See the following page for help: http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008743b.html
One thing I notice you must either enable logging or disable it specifically. Try running this command to see if it helps:
no ip dhcp conflict logging
Hope this helps.
Steve
VIP Purple
looking at your config, try and make the following changes; also, make sure the SSIDs match with those on the clients:
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.1.5.1 10.1.5.100
ip dhcp excluded-address 10.1.5.200 10.1.5.254
ip dhcp pool sdm-pool1
--> no import all
network 10.1.5.0 255.255.255.0
dns-server 10.1.4.5 10.1.4.6
default-router 10.1.5.1
bridge irb
interface FastEthernet4
description $ETH-WAN$
ip address x.x.x.47 255.255.255.224
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
crypto map SDM_CMAP_1
interface Dot11Radio0
no ip address
ssid Keta
vlan 1
authentication open
infrastructure-ssid optional
ssid Keta-Wireless
vlan 2
authentication open
guest-mode
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
--> ip address 192.168.1.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Vlan2
no ip address
ip nat inside
bridge-group 2
interface BVI2
--> ip address 10.1.5.1 255.255.255.0
GP
Community Member
Thanks all for the suggestions. I will be going up to the office shortly just to try these. The only thing I see with changing VLAN1 IP address is that I need that to stay what it is if possible. I will have corporate over a vpn depending that the range in this office be 10.1.5.1 which is being nat'ed on the outside interface for internet access as well. Any particualr reason I should change this to 192? Just asking - Im not completely sure how this will effect everything with giving the BVI the address instead.
Thanks again
118
