12-12-2001 08:59 AM - edited 03-01-2019 07:43 PM
Dec 11, 2001, 8:12pm Pacific
HI guys,
This i smy problem.
I have Three routers that are in ROMMON. I already know how to copy the image to the routers doing the xmodem.
What I need is to copy the image from a TFTP Server to the router. I did the following:
rommon 1 > set
rommon 2 > IP_ADDRESS=192.5.5.1
rommon 3 > IP_SUBNET_MASK=255.255.255.0
rommon 4 > DEFAULT_GATEWAY=192.5.5.0
rommon 5 > TFTP_SERVER=192.5.5.2
rommon 6 > TFTP_FILE=c2600-d-mz.121-4
rommon 7 > tftpdnld
This is exacly what i wrote. The IP 192.5.5.2 is the IP of the computer running the TFTP.
what I get with this is a time out error 1.
Also in a document from cisco says that I need to connect the router to the FIRST LAN PORT what is this? How Do I connect the router to the TFTP Server?
Thanks for your help.
PS this router are from a lab just to do the CCNA.
Thanks Julio
12-14-2001 07:55 AM
Julio,
Assuming that you are using Ethernet, you'll need a cross over cable or hub/switch to connect the router to the TFTP server PC.
Also, if memory serves me correctly, if you are attempting this on a 2600 that has a token ring & ethernet interface, and you are trying to tftp via token ting, you need to set a variable to tell the router to use the token ring interface and not the ethernet which is default.
In answer to the FIRST LAN PORT, I think if your 2600 has more than one ethernet port you have to use a specific port rather than being able to use any of them.
Best Regards,
Carl
12-14-2001 08:27 AM
Thanks for your help. I got the connection working the only thing I was missing was to set the
Gateway on the router the same as the IP on the computer this force the network connection.
I use two ethernet cables straight one from the router to a switch and the other from the computer to the switch. Using the fastethernet 0/0 port from the router
rommon 1 > set
rommon 4 > DEFAULT_GATEWAY=192.5.5.2
rommon 7 > tftpdnld
It worked great it downloaded the image in less than 30 seconds.
