Community Member
pls give me advice for switch config.
i have catalyst 3550/12gibic switch & catalyst 2950g 48 port switch how i can
configure both the switch i have given hostname,ip address,password both
for previllage & telnet i create cluster,vlan1,vlan2, is this sufficient
i can see frontpanel view
i can see topology view
i have assign ip address only vlan1
pls give me any suggession for configure the switch
1 REPLY
Community Member
Re: pls give me advice for switch config.
The configuration you have on them should work, but you may want to get with Cisco to help with the configuration if you have special needs in mind.
77
