I need to set up my router so that any IP address is NATed depending upon where it is going. It looks as If I will need to use route maps. So far this is what I have come up with:
interface Serial1/1:1
description T1 to --------------------
ip address 10.x.x.2 255.255.255.0
ip nat outside
encapsulation ppp
interface ATM3/0.1 point-to-point
description Line to ----------------
ip address 172.x.x.114 255.255.255.252
ip nat outside
pvc JNET 7/33
vbr-nrt 10000 5000 256
oam-pvc manage
encapsulation aal5snap
interface ATM3/0.33 point-to-point
description pvc to-----------------------
ip address 10.x.x.85 255.255.255.252
ip nat inside
pvc Mt-Holly 3/33
vbr-nrt 570 285 32
oam-pvc 0
ip nat pool natpool-0 10.x.x.1 10.x.x.254 netmask 255.255.255.0
ip nat pool natpool-1 172.x.x.1 172.x.x.254 netmask 255.255.255.0
ip nat inside source route-map MAP-M pool natpool-0
ip nat inside source route-map MAP-J pool natpool-1
access-list 10 permit 0.0.0.0 255.255.255.255 10.40.100.0 0.0.0.255
access-list 172 permit 0.0.0.0 255.255.255.255 172.X.X.0 0.0.0.255
route-map MAP-M permit 10
match ip address 10
route-map MAP-J permit 10
match ip address 172
Is this config correct? I need IP's comming int a3/0.33 to be NATed differently depending upon if they are going out s1/1:1 or a3/0.1.
