Pls help on MIB issue for Cisco 3560
smartboy2255
Hi all,
   I have uploaded CISCO-ENVMON-MIB.my for my Cisco 3560 Switch. But I would like to know what all details I can able to view? Is it possible to check the temperature, power details etc. Now I am able to see only Power and fan status ok only.not more info..
IOS is 12.2 25 SEB4
pls help
Ajith
phiharri
Greetings Ajith,
Try an snmpwalk on ciscoEnvMonMIB and you'll see all the available objects.
Monitoring is limited on the 3560, there is no granular temperature sensor but an overtemp sensor that you can read the state of with chassisTempAlarm (1.3.6.1.4.1.9.5.1.2.13) - same data as 'sh env temp' in the CLI.
ciscoEnvMonSupplyState (1.3.6.1.4.1.9.9.13.1.5.1.3) will give you the state of the power supply - same data as 'sh env power'.
/Phil
