kvc
Point-to-point subinterface over leased line
I have a 64k leased line between two sites. Can i have a configuration
like this
interface serial0
no ip address
encapsulation hdlc
interface serial0.1
ip address 10.10.10.1 255.255.255.0
interface serial 0.2
ip address 10.10.20.1 255.255.255.0
Similiar configuration at the other side.
The requirement is to create two virtual pipes and rate-limit the traffic on each
of these pipes.
Is the above configuration possible?
Re: Point-to-point subinterface over leased line
What you are trying to do requires multilink ppp. I have done a little of it with VoIP about a year ago. But I don't know if your link is too slow ( I was working with 512 KB).
This might help.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios112/112cg_cr/4cbook/4cppp.htm#19282
Good Luck
It can also be done with Frame Relay encapsulation, and
(for something slightly more exotic) ATM-DXI encapsulation.
It cannot be done with standard HDLC encapsulation.
Note that you can use Frame Relay encapsulation without
being connected to a Frame Relay switch. You need to
either configure the router at one end for FR switching,
or turn off keepalive (which will turn off LMI).
kvc
Thanks for the reply.
145
