Webcast-Catalyst9k
point-to-point T-1, same network - Best way
We are installing a point-to-point T-1, using 2610 routers on each end. Both physical locations will be on the same network 10.0.0.0/24.
Clock will be derived from the Telco Switch.
We're looking for a config example and advice/warnings, etc.
1 REPLY
Re: point-to-point T-1, same network - Best way
To configure this point-to-point T1 connection, you need some information from the Telco and setup your CSU/DSUs accordingly. For example, linecode, framing, clock source etc needs to be configured as told by the Telco on the CSU/DSU (external or inbuilt)
Also the following documents might be of some help:
http://www.cisco.com/univercd/cc/td/doc/product/access/multicon/3810soft/cmdref/e1t1ref.htm
http://www.cisco.com/warp/customer/116/t1_back_to_back.html
96
