Community Member
Point to Point T1 Issues
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
I have been asked to configure and ship two Cisco routers with configuration for a point to point T1.
However, when the customer plugged in the configured routers --- nothing happened. They were able to ping the Router on their physical side of the T1, but not the other. Any ideas? Configs provided below.
Thanks for your help.
Cisco-Broshco#sh run
Building configuration...
Current configuration : 420 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname --moderator edit-- Router1
enable secret 5 --moderator edit--
enable password --moderator edit--
ip subnet-zero
interface FastEthernet0
ip address --moderator edit-- 10.10.10.13 255.255.255.0
speed auto
interface Serial0
ip unnumbered FastEthernet0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
Cisco-Broshco#
Serial0 is down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Interface is unnumbered. Using address of FastEthernet0 (--moderator edit-- 10.10.10.13)
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
--moderator edit-- Router# sh run
Current configuration : 483 bytes
version 12.2
ip subnet-zero
ip address --moderator edit-- 10.10.10.12 255.255.255.0
speed auto
interface Serial0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
Community Member
Re: Point to Point T1 Issues
Also I will mention, the down status of these interfaces is because these clips were from the home office, and not while plugged in.
Bronze
Ryan,
The fast ethernet interfaces on both routers have been given IP addresses on the same subnet (192.94.210.0/24). Each router considers addresses in that range to be connected to the FaE interface, so pings from one router to the other will not follow the default route you have put into the configuration.
You must assign different subnets to each fast ethernet segment.
Good Luck.
Mark
Community Member
I'm not sure how to remedy this, as the telco gave me only that information with a mask of 255.255.255.0. I see what you are saying, however I am slightly confused. They are running bridges right now with that same ip/mask schema and it does not seem to cause them a problem.
Also, the fact that I have not set clocking (internal/network) on either of these routers would not cause this undesired behavior (or lack thereof), would it?
Community Member
Hmm, is there a way to fake a /30 between the routers so that traffic will pass?
I would rather not tell this guy he has to buy more Ip space!
Community Member
What if I replaced my zero route with something like this:
Cisco-Jay
interface serial0 - ip address 192.168.0.5 255.255.255.252
ip route 192.94.210.0 255.255.255.0 ser0
Cisco-Broshco -
interface serial0 - ip address 192.168.0.10 255.255.255.252
Bronze
If they had bridges and want routers they need to split up the address space. Cut it in half and use an address from each half in the router. Problem is they may half to change a lot of addresses in the hosts at each end.
Maybe they just want you to set up a bridge with the routers. The IP addresses they gave you could be for management access. Do you have any requreiments?
Community Member
They do need to change the hosts. They want to split them off so traffic is more "contained".
So a new scenario has arisen...
We have:
192.94.210.0/24
192.94.211.0/24
I will configure the router on each side as 192.94.210.1/24 and 192.94.211.1/24 respectively. Here is the corker. They are currently using 192.94.210.15 as their default gateway to the Internet. This is the firewall that manages inbound/outbound. Now that they are splitting off the subnets onto two different "networks", how will I direct the users on the 211 subnet to use the gateway on the 210 subnet? I do not think I can configure the hosts with 192.94.211.x IP addresses and /24 subnet to use the 210 address as their gateway. So they must be using the router on their end as the gateway to get across the network.
Will adding an ip default gateway of 192.94.210.15 on the 192.94.211.1 router allow these users to access the Internet through the firewall on the other network? Or how is this accomplished?
Thanks in advance.
135
