Policy Based Routing on GRE Tunnel Interface
****My previous working Policy Based Routing configuration. When 192.168.1.0/24 and 192.168.2.0/24 passes FastEthernet1 they are rerouted to 10.10.10.1 which the exit interface is FasEthernet0.
Interface FastEthernet0
ip address 10.10.10.2 255.255.255.252
Interface FastEthernet1
ip address 192.168.3.1 255.255.255.252
ip policy route-map INT-EXIT
access-list 100 remark INT-EXIT
access-list 100 permit ip 192.168.1.0 0.0.0.255 any log-input
access-list 100 permit ip 192.168.2.0 0.0.0.255 any log-input
access-list 100 deny ip any any
route-map INT-Exit permit 10
match ip address 100
set ip next-hop 10.10.10.1
**** My new NOT working Policy Based Routing configuration. IT seems that 192.168.1.0/24 and 192.168.2.0/24 are not being captured by PBR that I put to Tunnel0 interface as well as FastEthernet1 and therefore they are not rerouted to 10.10.10.1 or FastEthernet0.
Interface Tunnel0
ip address 192.168.4.1 255.255.255.252
ip mtu 1500
ip ospf network point-to-point
ip ospf mtu-ignore
ip policy route-map INT-Exit
tunnel source Fastethernet1
tunnel destination 192.168.5.1
Question: What could be the problem here? is this something to do with GRE Tunnel?
Silver
Re: Policy Based Routing on GRE Tunnel Interface
In the configuration, since the access list has a destination address " any", this implies that the policy will have to to bypass the default route. So can you just try giving "set ip default next-hop 10.10.10.1" instead of " set ip next-hop 10.10.10.1 " and see whether it works.
Silver
Try removing the ip policy route-map on the fasthethernet 0 and see what happens.
395
