Policy-map on catalyst 3550
dear all,
how to configure policy-map on catalyst 3550 to shapping bandwidth. I've tried to setting that police-map in one of interface, but when I wrote sh policy-map interface fa0/1, in class-map field, the result are
class-map: policeIn (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
match: access-group 112qm_police_inform_feature: CLASS_SHOW
Could u give me a clue..??
thx.
..::rhiez::..
  • Other Network Infrastructure Subjects
Re: Policy-map on catalyst 3550
Hi Rhiez,
Can you paste the config for your policy and the class which you have defined.
Also I hope your fa0/1 is not a routed port?
Have a look at this link for QOS config on 3550 switch.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swqos.htm
Ankur
Hi ankur,
Here i paste my config :
class-map match-all websiteOut
match access-group 111
class-map match-all websiteIn
match access-group 112
policy-map internetIn
class websiteIn
police 512000 65536 exceed-action drop
policy-map internetOut
class websiteOut
interface FastEthernet0/1
bandwidth 512
switchport access vlan 10
no ip address
service-policy input internetIn
access-list 111 permit tcp any any
access-list 112 permit tcp any any
Port fa0/1 connected to my proxy server via unmanage switch.
one question again :
Is there possible to setting service-policy input and output on same interface..??
thx
..::rhiez::..
Hi Rhiez,
You can apply a policy map to the input or output of a particular interface.
Only one policy map per interface per direction is supported.
HTH,
Ankur
Silver
In your show policymap output it seems to be refering someother policy map (policein). If possible could u attach full config with the sample output of show policymap and show classmap.
Using service-policy command it is possible to assign single policymap to multiple interfaces or multiple policymaps to single interface with the maximam of one in each direction.
Purple
The 'show policy-map interface' command is not supported on the 3550. While it will work if you type it in, the statistics will not reflect any useful statistics.
To monitor your traffic, you should specify the DSCPs to be monitored by using the 'mls qos monitor dscp dscp1 ... dscp8' interface configuration command, and then you should use the 'show mls qos interface statistics' command to view the stats.
Hope that helps - pls rate the post if it does.
Paresh
hi balajitvk,
here I paste my output show policy-map
switch# sh policy-map interface fa0/1
FastEthernet0/1
service-policy input: internetIn
class-map: website (match-all)
0 packets, 0 bytes
match: access-group 11qm_police_inform_feature: CLASS_SHOW
class-map: class-default (match-any)
0 packets, 0 bytes
match: any
0 packets, 0 bytes
5 minute rate 0 bps
could you give me a clue..
thx
..::rhiez::..
Silver
from the above output i don't think there is any traffic coming to that particular port. becz there no hits or drops in website in classmap.
Unclassified traffic (traffic that does not meet the match criteria specified in the traffic classes) is treated as belonging to the default traffic class.
But in our case, there is no traffic in default class also. Pls. chk the trffic by using interface status in both side of the link.
Rgs,
hi,
i've checked statistic of interface and there is traffic on that interface :
Hardware is Fast Ethernet, address is xxxx.xxxx.xxxx.xxxx(bia xxxx.xxxx.xxxx)
MTU 1500 bytes, BW 512 Kbit, DLY 100 usec,
reliability 255/255, txload 102/255, rxload 42/255
Keepalive set (10 sec)
Half-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last clearing of "show interface" counters 00:03:16
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 85000 bits/sec, 67 packets/sec
5 minute output rate 961000 bits/sec, 201 packets/sec
12965 packets input, 2137646 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
38564 packets output, 23504798 bytes, 0 underruns
0 output errors, 46 collisions, 0 interface resets
0 babbles, 0 late collision, 62 deferred
is there another way to shapping bandwidth per vlan or per port interface on catalyst 3550 with IOS 12.1(8).
thx.
..::rhiez::..
pkhatri is correct here. Although the show command will disply the policy-map it does not display any statistics. The only way to show whether the classifier/policer is working is by enabling the monitoring of DSCP values:
mls qos monitor dscp 0 8 24 26 32 46 48 56
mls qos monitor packets [bytes]
If you then type 'show mls qos interface statistics' you can see the ingress and egress DSCP values for the ones that were listed above, the ingress also shows a before and after the packets are classified, there is also a column showing packets dropped.
Andy
464
